I have this TrendNet PCI card connecting to a Linksys WRT54G that is one floor up and 2 rooms over (about 30 feet). Every 30 to 60 min my connection drops then I?m reconnected a few seconds to a few minutes later. I noticed a lot of the reviews on newegg for my card have the same problem. Should I buy a new wireless card? I was thinking of buying this Linksys card.
Or should I buy a better antenna for my current card. I live in a condo and ther are about 4 other routers in the area on channels 6 and 11, mine is set to channel 3. I plan on switching to channel 1 tonight to see if it helps. Also should I disable mixed mode of b/g and only use g?
Thanks for your help in advance.
