Wireless connection is slow on desktop, need help resolving issue
bball1523
271
Wireless connection is slow, needs help resolving issue. I have a Linksys Wireless - G PCI Adapter with Speedbooster (Model #: WMP54GS) for my desktop, and it has been acting slow lately. The house I live in uses some sort of D-Link Wireless Router, not sure what model. What's weird is my laptop's wireless works fine, but my desktop goes slow.
I tried checking for spyware, but that didn't help. I disabled Windows Firewall, but that didn't help.
Does anyone know what the issue is?
akhilles
336
Could be as simple as the type of wireless networks. If your wireless adapter is G, you have to set up the router to use ONLY G or else, it may degrade to B.
Also, could be interference. The distance between the router & pc and any objects in between. Your PC, unless in the same room as the router, will need a good antenna. Preferably, a directional antenna pointed right at the router. You can find the sweet spot by adjusting the direction of the antenna until you reach 3-5 out of 5 bars of signal strength in Windows. 3 is barely ok. Either get a directional antenna or build one out of aluminum foil/can. Google for guides. Basically, it's a foil on cardbard located behind the omnidirection (stick-like) antenna. The size of a letter will be more than enough. It's ugly, but it'll cost you $20+ for a good-looking one. Dlink makes one. Ebay has them as well.
bball1523
271
Interesting. I reformatted my computer and now my internet works a lot better, but from time to time it gets slow and doesn't load, but not as much as what was happening before I reformatted.
I did buy a Trendnet antenna and it helped somewhat, but still caused hangups in my wireless until I reformatted my PC.
What do you think the real problem was?
akhilles
336
If it's Internet hangups, it may be the signal strength. IMO, the 802.11b/g is only good for the same floor. Beyond that, you'll need an extender or a good antenna for the pc.
