wireless connection between two routers?
Garstud
I'm sure this has been explained before. I can't intelligently search since I really don't know the lingo and didn't have any luck. Sorry for that.
What I would like to do:
----phone cable---->|DSL wireless router|~~~~wireless~~~~>|MR314 wireless router|====ethernet cables====>|2 computers|
Hopefully this is clear.
Thanks guys.
Gary
The router wont connect wirelessy to your other router, you will need a Wireless Access point, and chock that to a router.
phone cable---->|DSL wireless router|~)))))wireless((((((`>| wireless Accesspoint|====|4 port switch|===ethernet cables====>|2 computers|
Unless the access point already comes with a 4 port ethernet switch.
Thanks for the reply ST.
So it is a "Access point" capability that I need.
This Netgear info page on the MR314 reports that it is an access point?
"The built-in Access Point enables the MR314 to be used in larger wireless networks in conjunction with other standards-based wireless access points. For additional ease of use, Auto Uplink ? eliminates the need for cumbersome crossover cables."
http://216.239.57.104/search?q=cache:9Z...14+access+point&hl=en&client=firefox-a
Thanks again ST.
Gary
Very few Entry Level Wireless Cable/DSL Routers can talk one to the other (95% can Not do it).🙁
Unless the data sheet lists the Router as a WDS:thumbsup: (or having the capacity to be configured as a Client, Group Bridge, or a repeater).
It will not talk to another Wireless Router.:thumbsdown:
Link to: Wireless Network - Configuration Modes.
If you want to Extend Wireless Coverage using a second Router May be this can Help.
Link to: Extending the Distance of Entry Level Wireless Network.
Link to: Using a Wireless Cable/DSL Router as a Switch with an Access Point
Link to: Wirelessly Bridging Home / Network.
:sun:
The LinkSys WRT54g can do what you want it to if you get the 3rd part firmware. In fact that what a lot of people on AT do.
"So it is a "Access point" capability that I need.
This Netgear info page on the MR314 reports that it is an access point? "
Actually no. You want bridging funtionality. Most budget AP's will bridge and that's why it was suggested. The device that says it's an AP is in fact an AP, it just cannot bridge.
Access Points can differ in their configuration capacities (varies form 2 to 5 modes).
Wireless Cable/DSL Router are combo Router/Switch/Access Point.
However in most of them theAccess Point part is restricted to One mode, and thus can not do other "dances and songs? beside talking to a Wireless Client.🙁
:sun:
