Wireless Card Problem
aatf510
1,811
I recently got a new Intel 2200BG intending to upgrade my Intel 2100 wireless card.
I swap the card, but now everytime right after my laptop POST.
I would get:
ERROR
Resource Conflict - PCI Network Controller on Motherboard
Bus: 02, Device 02, Function: 00
Press F1 to resume, Press F2 to enter setup.
I press F1 to resume, load into windows, install the drivers downloaded from Intel, but the card won't work and it has a exclamation mark on the icon in system properties.
Does anyone know what I can do?
Thanks in advace.
xanis
17,571
8
This should be in tech support...
AS for your problem, I would check to make sure that if you disabled a eithernet network card if you have one.
