I am trying to switch my router and wireless card between two computers. After lots of hassle installing wireless cards before, I figured I could handle any problems. Guess not.
I have a netgear MR314 router and a Linksys WMP11 wireless card. Both systems use winxp SP2. I installed the wireless card on my 2nd computer, set the essid, WEP encryption, channel, and password. Everything seemed ok, yet the wireless card cant find the IP address. I do show a good signal to the router. I check ipconfig and it shows some 169.xxx IP. So I go into TCP/IP and manually change the ip for the card to 192.168.0.1 with 255.255.255.0 subnet. Now everything seems ok it says its connected and I show a good signal. But I cant surf the web or access my router config page.
Then I try other options. I connect the router to a network bridge connected to a 1394 connection. I have no idea what a network bridge or a 1394 connection does. It doesnt work. Finally I uninstall the driver and the reinstall it before putting in the card thinking putting in the card first might cause the problems. It doesnt work either. What am I doing wrong?
