I just installed a new DLink 802.11b wireless card into a newly formatted xp machine, and for some reason, everytime I reboot, the wireless finds and says it is connected to the network with excellent strength, however it will not surf, or pull an ip address. In doing some trouble shooting, I found that I need to disable the wireless connection in the computer and then re-enable and it works perfectly fine, but still cuts out once in awhile. I have a laptop with an smc pcmcia card that works perfectly fine and never has problems. Would this be a bad card, or does it maybe just not like my SMC router? I am going to update the drivers and possibly flash the card when I get home from work tonight, but has anybody seen this before, or have any suggestions?
TIA
TIA
