Wireless can't access p2p, plz help
kuangs168
Banned
Sep 20, 2004
497
my laptop have built-in wireless card, i got wireless router at home and sometime use school's wireless network. either one wont let me connect to other p2p users or connections. i try use BT it should the seed info but wont start download. at winmx, even it said connected, the search won't comeup anything.
any idea?
dell 1350 wireless-g card
d-link di-624 router
wireless G connection
encryption off
norton internet security on and off both tested not helping
how to configurate it?
thanks
eigen
4,000
They have those ports blocked.Most schools do.
Pirate on your own bandwidth.
Edit: Does home ==dorm.
If not then, hmmm.
In linux I would say your ipconntrack tables are full.
In windows....
kuangs168
Banned
Sep 20, 2004
497
even at home my dlink router cant do it too... how to do port forwarding and which port best to use for p2p..? thanks again
vegetation
4,270
Just go to your router page and set it up. Use the users manual if you need to. It's your ports that aren't set up at home that's causing the problem. At school, those ports are specifically blocked.
