Wireless Cable Television?
ElFenix
102,408
8,596
if you have an all in wonder on one computer and radeons in the others you can stream tv to the others
poopygood
818
he wants to say put a tv in the sh!tter, with no cable wires running all over the place.
Mar 15, 2003
12,668
103
Originally posted by: wisfal
Is there a way to setup cable television up like a wireless network??
impossible.. there, i just answered your question ;)
You can wirelessly transfer one channel to all the tvs but not independently operate every tv with a cable box at every tv.. in other words, the raw cable feed (scrambled signal) can not be transmitted... you can try to wire things under the wall though and add coax sockets in every room..
Windogg
2.4Ghz Video/Audio Transmitter w/ IR Repeater
I remember seeing it for around $75 per unit. This is just the first link that came to mind and had good info. I do like the IR repeater which allows you to use your remotes as if the DVD/VCR/receiver were in front of you. A friend that got this told me that the microwave will warp the picture until you are done nuking your burritos.
Shop around and you can get it cheaper. Hope this is what you've been looking for.
Windogg.
Amorphus
5,561
Windogg.
If his microwave is leaking radiation, he should get a new microwave. :Q
Saulbadguy
5,573
12
Windogg.
This does not allow for cable signals though.
Jan 31, 2002
40,819
Windogg.
That's just a single-source transmitter - the OP wants something to wirelessly transmit the entire range of cable frequencies, which requires way too much bandwidth to be currently feasible.
- M4H
