Wireless bridging
acole1
1,543
Can I bridge two D-Link DAP-1360's together or do I need a D-Link router then the extender?
Also, can anyone recommend a cheaper bridging option? The distance is only about 30ft, but it is across a driveway and one building has metal siding.
skyking
22,889
6,056
Look at the control panel in the router. I bet you could do it.
As for the siding, remember windows are your friends:)
JackMDS
29,563
432
Features says.
"Create or Extend a Wireless Network in Your Home or Office.
Easy to Install and Connect with Wi-Fi Protected Setup.
Secure Wireless Encryption Using WPA/WPA2 Security,
Multiple modes: Access Point, Bridge with Access Point, Repeater, or Wireless Client".
If this is correct, then you should be able to Bridge.
Best result will be putting it in two Windows that look "eye to eye".
In the inside they should be plugged to a switch on the Network with a cable.
:cool:
