Fiber has finally arrived to my street and I'm going to sign up for it next week, but I have a problem: the point where the finer is going to arrive to my home is not where I have the router and the server, and as I don't have the house wired I need to do something about it.
Wring is out of the question, and the only viable solution I can find is a wireless bridge, but the area is really crowded with WiFi signals in the 2'4GHz range (heck, I have 3 AP's myself).
So I need a solution to make a wireless brigde with the two AP's like 3 meters apart with 2 walls in between and I want to be able to use the full 100/10 connexion, so a stable 100Mbit/s is a must.
The setup will be as follows:
I just need to buy the bridge, any recommendations? I suppose that the best bang for the buck will be to buy a coupe of routers and flash them with dd-wrt. I don't have a defined budget, I'm gonna spend as much as I need to make it work, but I'd like it to be as cheap as possible (without compromising quality).
Will this increase the latency too much? I need to remote to the server, and it also streams video and music (Plex) when I'm not at home.
Thank you.
Thank you.
