Wireless and Wired Network not mixing
mrlayance
Hello,
I have a wireless network setup and everything to functioning fine. I have a second computer that I want to connect to it via a wired router I have. Everytime I am connected to my wireless network and plug in my wired network my wireless connection drops.
I have everything setup with static ips.
Using my psychic fish + taco abilities, my vision shows two routers = bad. Sorry the vision is hazy, please send more money clarify my psychic vision.
Or provide more details.
Great network drawing of all time
"P
Basically computer 4's wireless connection craps out when it is connected to Computer 5.
Check to make sure ICS is properly set up on the wireless connection on Comp 4, check the configs on the wired connections on 4 and 5.
With 4 and 5 connected, can they ping each other?
No idea, but it's fixed. Check the event viewer and a thousand network card errors. Swapped it out and configured, works fine now.
