So basically i will show my problem and if someone has a suggestion than i can try that. if no real suggestion then its time for a production recommendation!
First off everything connections via Linksys WRT400N router.For reference (in regards to problem) my Asus EeePC can connect at 54Mbps with either excellent or very good signal strength even when right next to my desktop. Even sitting right next to the desktop (on top of the desk though) it can get 800-900kBps when downloading. The wireless is only used for internet, no streaming or anything like that.
now the questions/problem. my desktop has an older linksys wireless-G "speedboost" pci adapter. It only gets very low signal strength. With the antenna point vertical it could only get connected speeds of 11mbps. Turning it horizontal i was able to get to 36mbps. Still only very low signal no matter what position. Download speed wise really fluctuates. Sometimes it does well and get the 800-900kbps (semi rare) it normally gets 300-400kbps. I have updated to latest drivers and all.
Thanks for any advice/recommendations
Witht hat in mind is there anything else to try to get better signal strength/speed?
I am thinking not so i was considering just getting a new card. Wireless-N for sure. I am thinking a usb might be the best since i can put it on top of my desk. Most dont seem to come with a usb cord though, so any disadvantage to using a usb cord with them? Any suggestions as to which one to get? Seems like even wireless N ones range from 30 bucks to 70-80bucks so not sure which one is really the best?
