Adpater 2 is both b/g. Would that be a problem with my router, which is b only? I'm sure these cards can run in b only mode, no? I'm a little confused because if I get a new router in the future, I would want g compatibility. If I get the b only card, i'm out of luck. However, I want that extended antenna.
