E echo4747 Golden Member Jun 22, 2005 1,979 156 106 Feb 2, 2009 #1 Can somebody reccomend the best wireless "n" adapter with good range and speed. I need usb interface and would like to spend less than $100
JackMDS Elite Member Super Moderator Oct 25, 1999 29,563 432 126 Feb 2, 2009 #2 For Draft_N you need a Draft_N source otherwise it is a waste of money. Since the source is Draft (No standard) your best bet is to buy the matching Wireless card of the same brand. Otherwise a good inexpensive 802.11g. PCI, http://www.newegg.com/Product/...x?Item=N82E16833315041 PCMCIA, http://www.newegg.com/Product/...x?Item=N82E16833315047
