Wireless access point?
Heller
6,551
i want to get a wireless access point to hook up my xbox and such, now my wireless router isin the room across the hall so i dont want to run a ethernet cable across the hall, so my choice is an wireless acess point, soo is this how it works?'
i plug inthe access point across the hall, it wirelessly picks up my signal, i then put an ethernet cable from the acess point to the xbox, correct? or do i have to run a cable from the wireless router to the access point?
Kaido
Feb 14, 2004
51,980
7,418
I think that you're thinking of a repeater. All an access point does is converts a wired port to wireless. The easiest thing to get is a wireless adapter for Xbox. Microsoft and Linksys sell them, among other companies. Just google "Xbox wireless adapter" :)
JackMDS
29,558
431
Originally posted by: Heller91Ii plug inthe access point across the hall, it wirelessly picks up my signal, i then put an ethernet cable from the acess point to the xbox, correct? or do i have to run a cable from the wireless router to the access point?
Make sure that you get an Access Point that can be configured as a client.
Access Point configured as a client is a Driverless Wireless card, it connects wirelessly to the Wireless Router, and can be plugged into the Game Box ( http://www.ezlan.net/Wireless_Modes.html ).
Access Points are usually expensive; there are Wireless Routers that can function similarly for half the price (look at the Buffalo line).
Heller
6,551
well i do have a spare wireless g router (belkin) but i called up tech support and unfortunitly this router does act as an acess point BUT it cannot do it wirelessly (like a bridge he said?)so he did say i woulda have to hook up ethernet cable acorss the hall which infacts defeats the purpose.:( thats why im weary on getting a router/acess point all in one like you said JackMDS.
Heller
6,551
like this?
http://www.amazon.com/Microsoft-R86-00001-Wireless-G-Xbox-Adapter/dp/B0000C5FMJ
thing is im trying to avoid spending that much, as make it more futureproof so if i do decide to get another console i could use it for that aswell.
Kaido
Feb 14, 2004
51,980
7,418
like this?
If budget is an issue, hack a router! $40 will get you what what is basically a "wireless ethernet switch". Check out my thread here for more details:
http://forums.anandtech.com/messageview...atid=36&threadid=1952411&enterthread=y
Newegg has the router for $40 shipped here:
http://www.newegg.com/Product/Product.asp?Item=N82E16833162173
Here are the instructions for setting up the second hacked router in "bridged mode", which allows you to use it as an Ethernet switch like you want, but over the wireless network instead of a cable:
http://www.wi-fiplanet.com/tutorials/article.php/3639271
Heller
6,551
can i use the current router i have as a spare?
belkin wireless g?
JackMDS
29,558
431
belkin wireless g?
Look at the data sheet of the Belkin, some of the Belkin Wireless Routers can do client mode, if it says that it can do WDS you can probably use it as a client.
Heller
6,551
i would but , im not good with flashing and etc and if i could get this thing thats alrdy done with for the same price,imho its worth it for me.
JackMDS
29,558
431
The Buffalo WHR-G54S is $30 on Buy.com with Google exit. $39.99 on NewEgg.
It is WDS as is no need to flash.
Kaido
Feb 14, 2004
51,980
7,418
Shoot, ordering another! lol
Heller
6,551
so the one from buy.com will work for what i need without having to flash?
JackMDS
29,558
431
It would work in client mode with another Buffalo, Linksys, and other Routers.
With some, it might Not work.
Option 1. Hesitating forever.
Option 2. Buy the Router; return if it does not work.
Option 3. Buy a Game adaptor from the same Brand that makes your current Wireless Router.
