- Mar 10, 2015
- 1
- 0
- 66
I have a Netgear WNDR3700 connected to my FiOS G1100 to get better wifi connection on my second floor as the G1100 is in the basement, and upstairs the connection was spotty at best.
I have it set up as an Access Point, with the same SSID and same WPA2 settings as my G1100. So my devices didnt have to jump to a new network. The problem Im having is devices automatically jumping to the stronger signal.
On my LG G4 I have to manually turn off, then turn on my wifi, in order for it to pick up the stronger signal upstairs when wandering from the basement, and vice versa.
Is there a way for it to just reconnect to the stronger signal? Purhaps a setting on the G1100 or the WNDR3700?
I just want my devices to regognize the stronger signal, and automatically switch to it. Or maybe reduce the wifi power in the G1100, so that it is basically completely lost when I go upstairs, so that my devices will connect to the stronger signal.
