I'm hoping someone can tell me what I'm doing wrong because this problem is driving me insane and I don't know anything about anything.
I have a Sky SR101 router as my main point of connection to the internet in the house. However, there is a Wifi deadspot in an upstairs room that I need covered. I already have a Cat5 cable trailed from the SR101 to the upstairs room ready for a wired connection, but I need wireless coverage instead.
What I am attempting to do is place a Wireless Access Point there, using a Tenda W311R+ connected to the SR101 through that Cat5 cable.
I have read a pages and pages of instructions on how to do this but none of them seem to work.
This is what I have done so far
The Sky SR101 has the following settings:
LAN IP: 192.168.0.1
DHCP range: 192.169.0.11 - 192.168.0.254
WPA2-PSK (AES) security
I connected the Tenda W311R+ to a laptop that had no other internet connection, updated the firmware to the latest version, then changed its LAN IP to 192.168.0.9 and disabled the DHCP server, ensuring the security settings are the same and UPnP is disabled. I kept the SSID different so I could know which connection was being made on each device.
However, when I disabled the DHCP server, the laptop could no longer connect to the W311R+, even after several reboots of both the laptop and the router. My limited reading around the subject has taught me that this is an obvious consequence, as disabling the DHCP server means the router is no longer handing out IP addresses.
I have tried many many times in vain to connect to the W311R+ by giving the laptop a static IP but I must be doing something wrong. Also, I do not know what connecting to it will achieve because as far as I've read, the settings I've changed on the W311R+ are all I apparently need to do in order to get the damn thing to work as a Wireless Access Point.
I've even tried hooking the W311R+ up to the SR101 despite not being able to connect the laptop to it after altering the settings, just to see if it will work. After connecting, I power cycled both routers. Devices can see the W311R+ as broadcasting a signal, but they cannot connect to it - it won't even get to the stage of asking for a network key in order to complete the connection.
Somebody please tell me where I'm making a mistake or what to do next.
LAN IP: 192.168.0.1
