Wireless A - B - G
Crism
534
Which is the best for home use? I want to transfer files from PC's that are wired to the wireless laptop. I may or may not stream movies. I probably will be streaming music though. Also, I need internet which is 2-3mbit download. I plan on a router and a PCMCIA card. Which wireless technology is good? I will also be playing games online.
MistaTastyCakes
1,607
If you're on a budget, B would be a good choice. It can stream DivX and music just fine, and surfs the internet at good speeds as well.
