wireless 5.1 system
mrrman
8,497
What are good wireless 5.1 stereo systems? My friends have a Sonus but I am not sure I want to spend that much. Does anyone have good recommendations for this.
mrrman
8,497
I dont want to have cables running to my receiver and to all the speakers. I have that now and want to get rid of most of the cables. I know the soundbar connects to the receiver which is fine but the others do not.
sdifox
101,207
18,220
Do you have ac receptacles near where the speakers are/will be? They still have to be powered somehow
JeffMD
2,026
19
Sonos is expensive because of its wireless system, not because of its lackluster sound quality. It uses wifi and each speaker has a wifi network interface inside of it. Not sure if you are forced to use the sonos base system or if it can utilise your home router.
There is no home brew version of it. From sono it falls down to receivers and then utilizing some wireless speaker tech (usualy each tech handles 2 speakers/channels at a time).
Wireless speaker tech is still in fledgling stages due to no ready made standards for wireless audio short of bluetooth standards. This usualy means new tech that needs to be created has to tackle issues like signal degradation, interference, and latency.
