Wired vs. wireless
MGully8
33
Currently I have a media server that connects to my home network with an old network card and ethernet cable. I want to move it and I am wondering if switching it to a wireless card will effect the performance of streaming files? I use this system for media and I stream to my xbox located in my media center.
Also whats the best way to test transfer speeds on the network?
I have a Linksys wireless router (Wireless G WCG200) and would put a Linksys Wireless -G (WMP54G)
MGully8
33
Installed a wireless-g card on the media server that I have been using that was wired. When transfering a 100 mb file from the wired Xbox to the Wireless server it now took just over 4 minutes compared to 14 seconds when both were wired. With wireless I can't even stream to just my XBox with out it being choppy.
The question I have is wireless more CPU/Memory intensive? on the media server I'm currently using an old 550 mhz intel with 512 mb ram would that be what hindering it? Just a thought. I've been meaning to upgrade just been working on getting my XBox media center running before having to start something else.
Fardringle
9,200
765
If you are using encryption, wireless connections can use additional CPU power, but the primary factors in the speed data can be transferred on a wireless connection are quality of equipment, distance between the devices, and interference.
For testing purposes, put the media server a few feet away from the wireless router and try transferring that same 100MB file again. This will be your baseline transfer speed for wireless and will give you an idea of the maximum speed capability of your hardware when using wireless. If you get good results when close to the router (30-60 seconds to transfer a 100MB file over wireless is respectable) but not when in the desired location then you may have interference, or are just too far away from the router.
Make sure you don't have any of the common sources of interference in your house like 2.4Ghz cordless phones, high power microwaves in the path of the signal, steel framing, etc.
Also, use NetStumbler on a PC with wireless access (the media server would be fine) to see if there are any other wireless networks in the area that could be interfering. If there are, change your router to use a wireless channel that is not currently being used.
Having said this, wireless CAN be used to stream media once things are set up properly, but due to the many factors that can cause instability in the connection even after it is set up right, going wired really is a better choice for a media server in most cases.
MGully8
33
Thanks for all the information. I try some of those things this weekend and make a determination.
