wired to unwired
BigMoe
476
i have an three computers on a linksys router question i have an extra port on the router can i just buy a wireless router hook it up to that port to have a wireless network card on a laptop use the net? thanks
AFB
10,718
Yes, you need to disable DHCP on the new router and hook it up using a LAN port for both. You may need to use a crossover cable.
