Hi I just setup a new network. Here is the order:
Motoroal SB6121 --> NetgearR6100 --> TRENDnet TEG-S81g --> To 7 wired connections from home internal wiring through the main home cable box.
I have my main computer and HTCP both on a wired line through the TRENDnet TEG-S81g. I just set this up last week. The internet works great. Whenever, I tried to transfer large files or large amount of data, the wired network breaks down. I tried a transfer of ~16gb and it broke down half way. This has happened serveral time for transfers of various sizes. (Main computer lost all ethernet connection). It had to be restarted with wire replugged to get ethernet going again. I have transferred a few video files in size from 4-10gb of the network, thought they have transferred fine on the surface (full file transferred) when I try to play the video file breaks down in the middle of playing...I have to forward of skip past broken data points...loosing a few mins of video.
My networking wire in internally wired in the house with Cat5 cable. I am using Cat6 cables to connect from the Cat5 jack to the computer. Do I need to be all Cat5? I dont think this should make a difference, but right now I am trying to figure out what I can do to fix this.
Not only this but when I am transferring large amount of data, the speed is @~68MB/sec on the network, but if I try to surf the net at the same time its very slow. All other things on the network slow down. Any advice on how I can trouble shoot this?
Is it the switch that can't handle the load or is it the router? Any advice will be great. Thanks.
