Originally posted by: Brainonska511
If you only use the wired, you might want to check to make sure the wireless is disabled to prevent someone from borrowing your connection or snooping around on shared files.
Indeed Wireless has to be protected with at least with WPA, otherwise anyone who can get on the Network can access the HD Folders.
I use the process that was descried by me above only on my own system that I am, the sole user.
I would Not use it if there is other computers on Network that are used by other people.
Mistake can be made even when there is No malice, and it can lead to trouble.
In some systems as compromise I make a Folder under C:\ and build a subfolders system under it.
I only open the New Folder to Co-Ownership, so there is No need for a password to log to the Folder and its sub folder.
I copy into this folders the files that are part of the network shares.
However, it is the only the Folder (and its sub Folders) that are available to share. (kind of my own public Share).
