Problem:
After being in windows for about 15 min (sometimes less) my wired internet connection stops working (no internet or network access). Windows says that I'm still connected and when I check the connection details (ip address, subnet mask, DHCP server etc etc) everything is as it should be. Sometimes windows will give me the "limited or no connectivity" pop-up balloon. The only way I have found to get the internet or network services back is to restart the computer but that only gives me about 15min or so of access.
What I have tried:
This is a fresh install of Windows XP Pro SP2 with all updates.
While in windows I have tried to repair the connection.
While in windows I have done the startmenu>run>cmd>ipconfig /renew which doesn't work
I have tested to see if the connection freezes in Safe Mode with networking enabled and I get the same problem.
I have used the onboard LAN, I have used a wireless network card, and another wired NIC. Switching hardware doesn't help. The problem persists.
I have run virus/adware/malware/spyware scans all come back clean.
I have reset the router and plugged the computer directly into the cable modem same problem. I even called my ISP to see if it might be their problem but they didn't see any problems on their end.
THE SYSTEM:
Motherboard MSI KT6 Delta - with newest bios
CPU AMD Athlon XP 2000
RAM PC2700 512MB
Video PNY FX5500 128MB
AC97 onboard sound
and I have tried 3 different network cards one of which was wireless.
All system drivers are up to date and I have tried other drivers but still no worky...
Any ideas?
What I have tried:
THE SYSTEM:
RAM PC2700 512MB
AC97 onboard sound
Any ideas?
