- Feb 25, 2004
- 21,761
- 606
- 126
This is frustrating. I'm finishing a room in the basement and I would like to install a intercom in this room, one room upstairs and the kitchen. I either have pre-existing cat6 wire running do each location that I plan to reuse for one of the stations or its easy to wire the location from the basement access.
I keep searching for WIRED intercom's at home depot and amazon and elsewhere and they're all wireless it seems. The only for sure wired ones I've seen are video screen ones which are expensive and just not needed. I'm just looking for some cheap stations.
Anyway...I don't even care if I find one, I just want to know if they use cat5 or phone cable so I can confidently run the wire and have it ready. I don't even plan to install these for months. I assume they do, but I haven't been able to find a single one for sale!
