I'd been using a Linksys E2000 for a few years with no problem. I had a E2500 set up as an access point that worked fine for over a year as well. A few days ago all of my wireless devices said that they were connected, but limited and I couldn't access the internet from them. I removed the E2500 from the network since that was the one pretty much all the devices connected though and then connected though the E2000. Things seemed to work and then I added a TP-Link repeaters to extend the signal. Worked for about 10 mins and then the limited message came back. I removed the TP-Link repeater and still had limited connection with the Linksys E2000.
I have unplugged/reset the E2000. I have tried standing right next to it. I removed all security and left it open to see if I could connect and nothing worked. I replaced it with a old WRT160NL that I thought should be good and had the same results. Sometimes devices would work for small periods of time then stop. I ran ipconfig on tablets and everything looks ok. If I remove the connection and add it back then run ipconfig again, sometimes it will not have a gateway and will assign itself a 169.x.x.x ip address. I remove and add again it will go back to having a valid IP address and correct gateway and DNS.
Sorry for long post. Thanks for any help
