Equipment:
Netgear WNDR3700v1 wireless gateway/switch.
Wireless connection: three laptops (Windows 7)
wired connections: two desktops (XP and Windows 7), 360, ps3, media player, av receiver.
When trying to use remote desktop from the laptop, it fails to find the computer.
Even when I try to use the IP address.
However, I can access them from between the desktops without a problem.
If I run a game on the local LAN on desktop 1, desktop 2 finds it, but neither laptops do.
Is there some trick in getting computers on the WLAN and the LAN to see each other?
Do I need another router that can support this?
It's as if certain packets between the WLAN and LAN networks aren't being shared.
Thanks.
Thanks.
