wire management
thesob40
121
Well pretty much, the wire management inside my computer completely sucks. I have a side window on my case and when people look at my computer, they are discusted by all the wires popping out all over the place. I was wondering if any of you guys had some tips on how to clean up the messy wires inside my case. Ive been looking at a sleeve kit but i heard it takes a good 5 hours to install. Any help?
i just tried to straighten the wires up a bit and got it to look like ...THIS. It still looks like crap.
SonicIce
4,771
thats not too bad, my friends' cases are alot worse. you can't even see their motherboard.
are you really using that huge wad of cables coming out of the psu? see if u can route some behind the psu and behind the mobo tray.
thesob40
121
the huge thing of wires comin out of the psu are the wires im not using bunched and and held together by a tie...ill try shoving them somewhere...see how much better it looks..
JimPhelpsMI
1,261
Hi, Pep Boys has sprial wrap in all colors. It just wraps around the leads. Should take less than 15-20 minutes to do. No need to remove the connectors. Good Luck, Jim
thesob40
121
thats is a very good idea...would have never thought of that. thanks
JimPhelpsMI
1,261
Hi The, Thanks for the thanks. My factory used spiral wrap 25 years ago. I still have a small piece in one of my junk boxes. Colored Spiral Wrap came many years later for the Auto boys. Luck, Jim
