WIP: Minimalistic MiniITX System
Discussion in 'SFF, Notebooks, Pre-Built/Barebones PCs' started by AkumaX, Jan 28, 2013.
  1. AkumaX
    AkumaX Lifer
    Apr 20, 2000
    12,641
    Since the main components are here, I'll just go ahead and post some pics.
    Components so far: H61N-USB3, i5-2500k, 2 x 4GB Samsung LP/LV DDR3
    Missing: SSD, PicoPSU 120w (150w/160w just to be safe)
    To Do: Going to have to modify the case.
    Note that I reversed the orientation of the back I/O plate to opposite of how it's supposed to be (higher), in order to fit the cooler.
    Debating on cutting a hole for the CPU fan, or finding a Scythe Kozuti (and maybe drill in air vents)
    There are versions of the acrylic case that are bigger, but didn't like them - will have to figure out what to do.
    The case I got here: http://www.ebay.com/itm/C0AA-S1-1-P...1552?pt=US_Computer_Cases&hash=item337f673210
    Alternate Versions: http://www.ebay.com/itm/I0P15B-H1-1...5789?pt=US_Computer_Cases&hash=item4ab8202aed
    [​IMG]
    [​IMG]
    [​IMG]
    Gonna dual boot Win7/OSX 10.8, heheh...
    _______________________________________________________
    4/15/13 update
    it's almost done! i got the parts for the AC power brick i wanted.
    also got the 2 x 120mm x 12mm height fans :)
    in the meantime, i changed to a z77 board and got a dual core ivy bridge instead.
    the tricky part is wiring it all together to the PicoPSU and hoping it doesn't fry everything i've done so far :p
    the top - [​IMG]
    the bottom - [​IMG]
    i/o ports - [​IMG]
    side angle - [​IMG]
    you can see the gap underneath the i/o ports
    there is a design decision that i could make - i'm still debating on whether i want that 120mm fan underneath the motherboard. should i just remove it completely and lower the motherboard?
    #1 AkumaX, Jan 28, 2013
  2. Loading...
    Similar Threads - Minimalistic MiniITX System Forum Date
    My $350 System Running: Rise of the Tomb Raider SFF, Notebooks, Pre-Built/Barebones PCs Oct 8, 2016
    Mini ITX Quiet Gaming build suggestions? SFF, Notebooks, Pre-Built/Barebones PCs Aug 24, 2016
    Suggested MiniITX system build. SFF, Notebooks, Pre-Built/Barebones PCs Feb 25, 2015
    Build check: Minimalist Mini-ITX HTPC SFF, Notebooks, Pre-Built/Barebones PCs Jul 31, 2009
    Micro-ATX or MiniITX case that has 2 5.25" 1 slim 5.25", 1 open 3.5" tray SFF, Notebooks, Pre-Built/Barebones PCs Jan 16, 2009
  3. TheStu
    TheStu Moderator<br>Mobile Devices & Gadgets
    Moderator
    Sep 15, 2004
    11,850
    9
    How you gonna power that sucker?
  4. AkumaX
    AkumaX Lifer
    Apr 20, 2000
    12,641
  5. TheStu
    Moderator
    Sep 15, 2004
    11,850
    9
  6. AkumaX
    AkumaX Lifer
    Apr 20, 2000
    12,641
  7. TheStu
    Moderator
    Sep 15, 2004
    11,850
    9
    #6 TheStu, Jan 30, 2013
  8. 2timer
    2timer Golden Member
    Apr 20, 2012
    1,803
    Wow, that looks nice, so cool to see something in it's actual form!
    I'm looking to build a SFF PC, so I have questions - lots of questions! :)
    Q: It's hard to tell, but are the sides of the case just open air? It looks like there is a top to protect against any collisions, but I can't tell if the sides are open or closed.
    Q: I don't see the standoff screws - is the mobo just resting on top of the tray? Are you planning to fasten it in with standoffs?
    Q: Regarding the HDD, so your plan is to buy an SSD and just remove the outer enclosure? Interesting!
    Thanks, great build!
  9. 2timer
    Apr 20, 2012
    1,803
    *Edit*
    Ahhh I see what you did there. The CPU cooler wouldn't clear the top in the original orientation, so you flipped the case upside down for more clearance! Nice.
    I'd drill a hole using a circular bit on the top, to give the fan some clearance.
  10. Anonemous
    Anonemous Diamond Member
    May 19, 2003
    7,361
    hmmm are you going to stick a discrete card in the pci x16 slot? Was thinking of building something like this for a ceton streaming/dvr box. Also where are you planning to put the ssd?
    edit: Ah, there's space under the mobo:
    http://www.lcdmodkit.com/specification/I0AA-H1.pdf
    #9 Anonemous, Mar 25, 2013
  11. AkumaX
    AkumaX Lifer
    Apr 20, 2000
    12,641
    no, the sides are also acrylic :)
    i'm considering drilling holes in the top to allow airflow. technically you shouldn't have the top open in case of spills/etc.. but maybe i'll side load it (or not drink anything near it :p)
    There are standoffs, however I did not use the ones that came w/ the acrylic kit in this picture. w/ your reply below (how i 'turned the case upside down'), i actually just turned the back plate's lcd part (not the i/o plate) upside down.
    because of how the build is done, i'm considering not even using the back acrylic plate. the dimensions don't match to what i need..
    yes, and i've already done that.
    you can kind of see how it looks in this picture.
    [​IMG]
    (that is the standard sata connector - not microsata or whatever, haha)!
    it's also as thin as it looks!
    however, i do not intend to use the space underneath for the ssd (see pic :))
    in my picture, the itx mobo is lowered because i didn't use the included standoffs (i used my own)
    also, that pic is of the 'recommended' case to be used with a core i3 setup.
    the case i got was technically only made for integrated setups (using an atom or via cpu).
    - http://www.ebay.com/itm/221204772256
    i'll figure out a way.. ;)
    when i started this project (months ago), i've never even heard of thin-itx.
    i researched it and initially i didn't consider it because it wasn't (easily) hackintoshable.
    but it seems like the newer motherboards are, so i might consider switching out the new Z77N-wifi...
    i wouldn't have had to worry about the picopsu if i went that route.
    p.s. the parts i wanted came in so expect updated pics tomorrow :p (including a new cooler, picopsu, and that scythe :))
    a lot has changed since then (but not worth updating.. yet - if i finish my next milestone this week i'll update it).
    main goal of this build is to dual boot osx/win8
    luckily for me, i was fine with the HD3000 (now HD4000) graphics.
    board has changed to a Z77N-Wifi.
    cpu downgraded from i5-2500k (a quad) to i3-3225 (dual), although graphics have changed
    also got a couple of scythe slim slipstreams (120mm x 120mm x 12mm high) fans
    the original design of this pre-built kit was that there are riser holes that raise the itx motherboard 17mm from the bottom of the plate
    - to allow for clearance of a couple of 2.5mm hdds
    - a small 40mm x 10mm height fan
    since i no longer need the clearance for the 2.5" drives, i could either a) lower it and eliminate the fan completely or b) slightly raise it to put in the 12mm height 120mm fan
    this reply got to long, should probably move to my thread haha
    #10 AkumaX, Mar 25, 2013
  12. MrX8503
    MrX8503 Diamond Member
    Oct 23, 2005
    4,531
    wow that's awesome! I didn't know such a thing existed. Thanks for sharing!
  13. AkumaX
    AkumaX Lifer
    Apr 20, 2000
    12,641
    4/15/13 update
    the top - [​IMG]
    the bottom - [​IMG]
    i/o ports - [​IMG]
    side angle - [​IMG]
  14. 2timer
    Apr 20, 2012
    1,803
    Where's the SSD? I don't see it in the update.
    Unless you can squeeze the SSD up top, I'm guessing there will have to be a slight gap between the mobo and bottom side, anyway. Are your thermals worrisome that you need the fan on bottom?
  15. AkumaX
    AkumaX Lifer
    Apr 20, 2000
    12,641
    I could have squeezed it up top or bottom. But them found out it could fit on the side :p
    [​IMG]
  16. 2timer
    Apr 20, 2012
    1,803
    Awesome, I love it! Good job on that one there OP.
    :biggrin:
  17. VirtualLarry
    VirtualLarry Lifer
    Aug 25, 2001
    35,781
    608
    That's a sweet ITX build!
  18. firewolfsm
    firewolfsm Golden Member
    Oct 16, 2005
    1,800
    Motherboard components don't really need cooling. Just lower the motherboard and widen the vents to increase air flow to the cpu. I think a quad core could easily fit in this system.
  19. MrX8503
    Oct 23, 2005
    4,531
    Very cool. How did you know which SSD has the smaller PCB when you cracked it open?
  20. AkumaX
    AkumaX Lifer
    Apr 20, 2000
    12,641
  21. RU482
    RU482 Lifer
    Apr 9, 2000
    12,682
