WinXP Pro Question
cornelio
Hello,
I use Zone Alarm Pro and to run chkdsk I have to disable a Zone Alarm driver which locks the hard disk. My question is that if I can make two different profiles, so I don't have to disable the zone alarm driver everytime that I run chkdsk or other program that needs direct access to the disk.
Any help appreciated.
Someone plz correct me if I'm wrong. I believe that you can create the other profile and disable it in the MSCONFIG under that profile. HTH
