Hi,
I have just finished upgrading my comp from a PIII to A64 with a new mobo(Chaintech VNF3-250).
I have a simple setup..nothing complicated right now:
- Two HDs - small ones
- Vid Card - Savaga AGP 4x
- 2x CDRoms
Now, when I go to install WinXP Pro, it goes through the whole process of copying files over and then says it can't copy certain files..like "clspack.exe" and others. After googling, I found that this file and the rest of the files are related to Java thingies.
My CD is not scratched at all. It is brand new. This is WinXP Pro with SP1.
So far I have skipped those files and going ahead with install...just wondering if I should be concerned about these files and if my XP will be stable or not.
ANyone know the cause of this?? Is it cause of AMD Proc?? Btw, the HD was completely formated(Long one).
- 2x CDRoms
