WinXP Pro and svchosts processor usage issues
Magum
Running Windows XP Service Pack 1 SVCHOST goes haywire on my machine taking up 90+ % of CPU usage after the machine has been in normal use for a while. Rebooting fixes the issue, but after a few minutes of just sitting SVCHOST starts hogging CPU cycles. This is on a recently formatted machine (done so twice) with the only change being a new Giga-Byte GA-8IHXP. Nothing is running in the background that could cause this issue, I used msconfig to selectively remove anything from start in registry that could cause this. Is anyone aware of some driver for the Giga-Byte GA-8IHXP causing issues such as this? Any ideas would help. Thanks
System Config:
Giga-Byte GA-8IHXP
Gainward Golden Sample G4 TI4400
Audigy
Integrated Realtek Lan
Koolance watercooled
512 Samsung pc800 2x256
430watt Enermax
WD 80gig special edition
plex 24x
pioneer slot load dvd
Windows XP Professional Service Pack 1
It might not be system specific but rather the software. Happening to me too. Did you just previously run Winamp? Because on my system, I used Task Manager to terminate the svchost that was eating up the cycles, and I find that Winamp can no longer output sound. And it happens that I can create the svchost processor usage by running Winamp for a while and closing it...
P4 2GHz
Intel 850MV mobo
256 MB RDRAM
Geforce2 MX400
