WinXP pagefile issues.. quick question...
Propofol
13
I just installed WinXP Professional on my P4 and I keep having this 1 minor issue:
When I was using the welcome screen logon, it would hang right at the blue welcome screen and would never show the users. When I switched to the NT-style login, it worked better, but after logging in I get a critical stop with this message:
Limited Virtual Memory
Your system has no paging file, or the paging file is too small. To correct this....
I go into the control panel and adjust the settings for the virtual memory and restart, but each time WinXP starts, the message pops up. It never creates pagefile.sys.... the registry entries are made though. I read something on Technet about a similar issue with NT having to do with permissions. Has anyone seen this before? I need to get my pagefile to work.. it's causing problems in applications.
