winxp login problem
iskim86
Banned
Jul 6, 2001
1,802
www.isaackim.org
one day windows xp started asking me to choose a user for my computer. there is only one account on this computer, and that is mine. it doesn't even need a password to log into windows, but all of a sudden it's asking me to choose a user. i know it's not that big of a deal, but I can't press the power button of my computer and go out anywhere, expecting it to log in automatically and run the startup programs. I have to be with the computer until windows shows the welcome screen. how do I fix this?
thanks
stars
1,068
How to Configure Windows XP to Automatically Log On a User Account
For Windows to automatically log on a user account during the startup process, the following must be met:
- The Welcome screen must be available
- Guest account access must be turned off
- There must be only one user account on the computer
- The user account must not have a password
To make the Welcome screen available:
1. Click Start, click Control Panel, and then double-click User Accounts.
2. Click "Change the way users log on or off".
3. Click to select the "Use the Welcome screen for fast and easy logon" check box.
4. Click OK.
To turn off Guest account access:
2. Click the Guest account.
3. Click "Turn off Guest access".
To remove the password from the user account:
2. Click the user account.
3. Click "Remove my password".
4. Type the password in the "Type your current password" box, and then click Remove Password.
Source: http://www.kellys-korner-xp.com/win_xp_logon.htm
iskim86
Banned
Jul 6, 2001
1,802
www.isaackim.org
all of the following requirements are met, but it still doesn't logon automatically. :( also, there is an account I don't recognize, it's called ASP.NET machine A....
daniel49
4,814
That asp is something you got from windows update as I recall It installed it in my user accounts also .I just removed asp from user accounts and it logged in auto again.
NogginBoink
5,322
This happens when you install the .NET framework service pack update from Windows Update.
I don't know how to fix it (assuming it even can be 'fixed'), but I've run into this before and the behavior is expected after installing this update.
nweaver
6,813
theAnimal has it right, that screen is the same one you were used to for Win2k
dawks
Yup, I had a fresh install of XP SP2 last week, and it would log in automatically, until I installed .NET, then I would have to click my user icon to login at the startup following the reboot from .NET's install. Then I installed .NET Framework 1.1 Service Pack 1, and just as the KB article says, the system auto logs in now.
