Hello,
I have a really strange problem with the swapfile settings on my Toshiba 5000-514 Laptop. I'm running Windows XP and I tried to disable the swapfile, or at leat let Windows use the whole 512MB RAM before swapping. This would reduce disk access, make the laptop quiter and save power. But Windows completely ignores my settings. When I disable the swapfile or set its size to a small value, Windows ignores it and continues swapping. I've also tried some registry tweaks, but they seem to be ignored, too.
I tried the following setting, which should reduce swapping and increase disk caching:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
DisablePagingExecutive=1
LargeSystemCache=1
But Windows still pages the kernel.
I have no reasonable explanation for this behavior and I would appreciate any hint or solution.
LargeSystemCache=1
