winxp + aureal sound card HELP!!!!!!
parkie123
I am having trouble getting my rear speakers to work with winxp (i have an aureal vortex 2 sound card) ... can anyone pleeeeeeease help?
This might help, it did for me.
Get into the mixer app (i.e., double-click the little speaker icon in the system tray) and under Options->Properties click "other" and choose AC97 audio from the list. Click OK and you should see a volume control with 2 sliders, one for the front and one for the back. For some reason they are set reaaly low. Slide them up until everything is loud enough.
<< This might help, it did for me.
Dude, you are the man, Workin! I just got this sound card, and I didn't know why it didn't sound as loud as my previous SB Live. Now, everything's A-OK...sweet! 😀
😱 Just passing on something I learned from someone else on these forums. Can't rememeber who it was, or I'd give them credit.
hrmph, i tried that, and for some reason, i see only one slider which is for front/rear. I turned it all the way up but my rear speakers still don't work 😕
