WinXP 64-bit Pro
Kodiak
576
Any program that uses Windows Installer won't work for me :( I'm on Build 3790 (SP1, v1443).
Examples: MSN Messenger, Konfabulator
Schadenfroh
38,416
4
How long has it been since you ran Windows UPdate, there was an update for the MSIs a little while back
Kodiak
576
I check once in a while, but there aren't any updates...ever...
Update for the MSIs? whats that?
ViRGE
Elite Member, Moderator Emeritus
167
I installed Konfabulator just fine last week. Schadenfroh is right, there was a Windows Update item posted back in May related to Windows Installer, you should pick it up.
