WinTV USB TV Tuner
rookie1010
Hi
I wanted to buy a Tv Tuner Card for my laptop/PC
i came across the following tuner card on amazon, it seems to have good reviews, what do you guys think of it
Hauppauge WinTV USB 2 Personal Video Recorder
http://www.amazon.co.uk/exec/obidos/ASI...=sr_8_xs_ap_i4_xgl/026-2951477-2228440
it is a bit pricey but allows recording programs, i intend to use it both on a laptop as well as my pc
do you guys know if it gets its power from the USB port or does it need to be powered independently?
Power
Type: Power adapter
Will G
edit i picked up the pci version of that i think on BF for like 25 bucks or something. works great for me.
so the pci version is 25 dollars/pounds and the usb version is 100 dollars/pounds
do you guys know of a hauppauge which does not need a power adaptor but gets its power from the USB port
no I bought that one on Black Friday here in the states. The day after Thanksgiving. Im not sure if there is a USB one that doesn't need a PS. You could try something like this.
Will G.
i'd stay away from usb type video capture/tv tuners. usb doesnt really provide enough bandwith for such purposes so expect lots of dropped frames etc.
also i looked at the specs in the link and i see no mention of capture/playback resolutions. ususally usb devices such as these are not able to produce anything near the quality that a decent pci card would.
Hi
I needed one which one fit both my laptop and my desktop,
i thought a USB2 capture card would not drop any frames since it works at 480 Mbps(?)?
fo a laptop should i just go for a PCMCIA solution then?
The thing is though i haven't found a decent PCMCIA solution for your needs the only one i found on amazon said it worked horrid.
Will G.
My Inspiron 9300 came with the WinTV external USB 2.0 tuner. It works great with my Comcast cable. The only drawback is that I do not have a Comcast digital box so the TV signal is analog.
I also use it on my old (in laptop years) Latitude C840 which only has a 2.0 Ghz P-4 and USB 1.1. I added a D-Link USB 2.0 PCMCIA card and it works just as well. Of course the 15" screen and video card in the Latitiude do not match the 17" 1920X1200 resolution screen and 256MB 6800 Go video in the 9300. I am also using the 9300's MCE 2005 USB IR receiver and remote control attached to the second port on the D-Link USB 2.0 card.
I recommend the WinTV USB 2.0 as a reasonbly priced external TV solution that can easily be moved from PC to PC as needed..
