wininet.dll problem
DemonEdge
105
My friend was told by his norton anti virus that he had some dangerous infections on his PC. After downloading Avast 4.1 free trial and scanning his PC he detected a trojan horse and proceeded to delete it. Then after rebooting his PC after logging in thru the users page he got the error message saying 'applications failed to load e.t.c wininet.dll is missing, replace the missing dll file to fix the problem' or something along those lines. After the message nothing loads up and he is faced with a blank desktop with no start bar.
Now using his other PC he has downloaded the missing dll and now he needs to know if there's anyway he can transfer it onto his downstairs PC.
P>s Will all his data/hardware sotrage/work be lost ior corrupted?
update: after saving the dll to a memory stick and then using task mamanger in safe mode on the errorer PC to copy paste the dll into the system2 folder my friend still has the same problem bnut instead the error message doesnt come up but he cant use any applications or open stuff and his desktop flashes. Any help?
Allanv
905
in safe mode put in the xp cd then open a cmd prompt and type
sfc /scannow
this will scan and replace the system dll's
or reinstall IE
AMCRambler
7,715
31
sfc /scannow
or reinstall IE
He's fixed the problem. Thread here
Demon, you should really just bump your thread rather than post again. Glad you got the problem fixed though!
