WinFast TV 2000XP problem and a startup problem
TJN23
Just started up my computer after pulling out a 2nd PCI video card and got a message:
Windows cannot find C:\Windows\System32\System32.exe - Please make sure you typed it in correctly. To do a search, click start, search, find files or folders.
Another unrelated (or maybe not?) issue: I tried reinstalling drivers for my Winfast TV2000XP card and they seem to work when I update them within the device manager. The drivers will be installed fine but then I'd need to install the application to be able to watch TV. When I install the application from the WinFast CD it goes through the installation, then toward the end it says are you sure you want to completely remove the selected components as if I was trying to UNINSTALL the program! I used install.exe from the CD...
TIA for any/all help
Tim
