If you can find 64bit drivers for all your hardware and have 4GB+ of ram then its a very good, stable and reliable OS to use.
I use it on my main rig. Drivers are all fine (much better than a lot of Vista ones atm) and I enjoy using it.
However, I don't think its worth the switch unless you need to access more ram though.
