Hi,
I am installing win2k pro on a laptop. i dont know what the spec of the laptop is, but i know that it had win xp on it previously and it is a (Packard Bell iGo), then an error message came up on boot up preventing the os from loading. so as i dont have a win xp cd, i am going to install win2k pro.
After loading the win2k pro cd, i get to the part where it says; "To setup win2k on the selected item, press enter" so i select "C: Unformatted or Damaged 28608MB", then it says, would you like to format the item using either ntfs or fat. so i select ntfs, then the screen comes up saying, Please wait while setup formats the partition C: Unformatted or Damaged 28608MB on 28616MB Disk 0 at id 0 on bus 0 on atapi; and below this it says; set up is formatting..... 0% and nothing happens, i even waited 20 minutes, still nothing. Tried a few times, and i cannot get past this stage.
Anyone got any ideas? All help very much appreciated.
Cheers, Mo.
PS: I just had a look in the BIOS and ive got some spec:
Internal HDD 30006MB
System Memory 640KB
Extended Memory 227328KB
CPU Type Mobile AMD Athlon(tm) XP
CPU speed 1600MHz
Cheers, Mo.
System Memory 640KB
CPU speed 1600MHz
