WindowME unable to shutdown completely !! Help !!
Spectrum
56
Hi folks,
My system specification are as bellow :
  • PIII 733Mhz
  • Kingston PC133 128MB SDRAM X 2
  • Asus CUSL2 Series (ATX, 133MHz FSB)
Albeit I have reinstalled the whole OS, it still doesn't work at all. Pls come and rescue ASAP !! Thanks !!
Regards,
Spec
Losty
1,136
try going into your power management and turn it off...this will make you manually push the button to shutdown, but i think there are some complications with windows ME and 733 mhz and up with hdd that have large cache
hope this helps...i could be wrong though
Spectrum
56
Hi Losty,
Thanks a lot for your help....I m using IBM Deskstar ATA100 7200rpm HDD. Will this HDD cause problem ? Thanks !!
Regards,
Spec
Fokks
371
Spectrum you should try doing a quick search of the forums here...
http://forums2.anandtech.com/messageview.cfm?catid=27&threadid=242583
try the patch that's linked through that thread, it's from microsoft even though it's off the micronpc website. microsoft acknowledged there's a bug with some of the newer faster hard drives with a large cache, like the one you have, on faster systems. what happens is windows shuts the pc down before it gets the chance to save to the drive what was in the temporary cache.
(here is the direct link to the patch)
MEATA100 patch
