Here is my problem...I accidently set the dll files to be open with wordpad. So I fix that that by going into folder option and file types tab and change it back to to be opened with unknown application. But the problem is: it's not like before when I just install WinME where when you click on DLL it wouldn give you a warning first before it let you go an select the program to open the file with. Now it would not give me any warning and just let me go and select the program to open it with. Furthermore, the icon of all the dll files is different from before now, I want to change it back.
Can someone help? Basically I want everything back to where it was when I first install WinMe.
