Windowed Computer Cases w/400 Watt PSU and Fan for 32.23 to 34.95
birdog
65
Computer Geeks has the cases again and some black ones also. Two different black ones and two different sliver ones. All have a pretty decent 400 Watt PSU and a multilight fan.
Power Supply Output:
+5V/30A maximum
+12V/25A maximum
-12V/0.8A maximum
+3.3V/28A maximum
-5V/0.3A maximum
+5Vab/2.0A maximum
The fan is a red and blue (2 red and 2 blue)
I ordered a silver one the first time and it is nice
Black Style 1 is $36.95 - 10% = $33.26 + shipping
Black Style 2 is $35.95 - 10% = $32.36 + shipping
Silver Style 1 is $34.95 + shipping
Silver Style 2 is $34.95 + shipping
You can use the 10% off code on the Black ones only (I have tried on the Silver and it wont work for me), the shipping is $10.00 for me
gtd2000
2,731
Originally posted by: tse200
these look pretty sweet...anyone already have one???
I built a system for a friend two weeks ago with one of these cases which has the top vent fan and the cold cathode tube - I think it was $48 shipped from Directron?
They are very cheap quality (lightweight) but perfectly acceptable for most users - no problems with it so far to my knowledge :)
doinmybestatlast
592
I ordered two this time. I ordered two previously and kicked myself when they went OOS. These are the best budget cases I have found so far and they look nice. The silver case is $34 and I picked up a second for 30. Put in some round cable from SVC and the cathode, or neon, light and you have a great looking case. CG also sells round cables but SVC sells the FD cables cheaper and shipping from them is just as reasonable. This case is much better than the Raidmax Aluminum case. The P/S is also better. This P/S is the best decent crappy P/S I have found. The LED case fan is quiet.
You want more...! at $34! It ain't happening!
Cerberus8080
"the power supply lacks the ATX Aux Power Connector (AKA Extended ATX - 6-pin
... straight) required by some older P4 motherboards"
Just make sure you read ALL the specs
Myth465
62
yes its a nice looking case i picked it up locally at directron in houston
but be sure to order some extra standoffs it only includes 2
SpideyCU
1,402
That silver case is nice for that price as-is; if the $10 rebate comes through, that's HOT.
SpeedBrkr
26
Originally posted by: ScroogeSF
uh...sorry for posting this on the boards...but wat's a standoff?
Correct me if I'm wrong, but standoffs are used to prop the motherboard up when you install it.
Aug 27, 2002
10,043
yes, they are the hex nuts that have a screw on one end and a screw input on the other for the screw to go through the holes on the motherboard.
edit:
forgot to say nice find btw...:)
SpeedBrkr
26
I'm about to order the silver and black ones! Is this truly a hot deal or should I wait? I eventually need to buy a case within the next 2 months. Help me decide quick before they are sold out! =D
Update: I ordered them!
Keltron
1,109
I ordered a black case for $30.29 after coupon. It is a Powmax case and has an LED exhaust fan.
btw its $33.65 before coupon not $36.95. You can't use coupon on silver case because it is Compgeeks special. you can tell what is CG special by the green dot. everything without the green dot has 10% off
