Window x64 Disk defragmenter engine is not responding
videopho
4,185
29
Added a 3rd party app that basically hosed up my window x64's disk defragmenter engine. Everything such as interface is still there but when clicked on "Analyze" or "Defragmenter" thread it not responding (NO hunging whatsoever). Here what I've done:
1) I have tried to use original x64 installion cd (install accessories) to no prevail
2) re-activate defrag32 driver (.dll) in WOWsys3r emulator.
3) tried to run in dos/cmd window
None has worked!
Is there a way to undo or recover this? THANKS
videopho
4,185
29
Originally posted by: stevty2889
Have you un-installed the 3rd party app that started the problem in the first place?
forgot to mention it. Yes it is gone.
videopho
4,185
29
Not quite recall the name but it was some disk backup utility for hard drive that only works when booting up from window. It came with the mobo cd drivers that I wished I'd never insatlled
amdskip
22,530
13
Do you have system restore turned on? That or formatting would be your options I think. I really don't see the point in running such a poorly supported OS.
