Window Repair (thing that lights light in, not O/S) Question
spacejamz
10,981
1,701
The adhesive that holds the glass to the window frame gave out so there is some separation between them...when I my A/C is running, it sounds like a jet engine (I assume because the air is being escaping through the gap - to stop the sound, I stuffed some weather stripping tape in the gap)
The windows are about 10 years old...Is this 'fixable' or should I just have the window replaced?
BoomerD
66,401
14,797
He needs some sticky stuff. Guess he could go back to using jizz. Works for hair gel, I hear.
It certainly looks good on you...
13,855
You will need to close the window, wait 10 seconds, then open it again and see if the problem is still there. If yes you might have to reinstall it.
On serious note, if the window came out of it's frame it's more serious than just gluing it back. The air inside (well more like lack of air) is now compromised and the window pretty much lost all of it's R value and you'll freeze in winter. You'll also get condensation inside at times. I have one of my windows where the seal broke and that's what happens. I need to get that replaced. Older ones are just a vacuum I think, though they might also have argon.
Number1
7,881
549
What kind of climate do you live in?
Typically, windows should last longer than 10 years.
What kind of windows are they, wood construction, plastic, aluminum and do you have pics?
in the olden days they used to use mastic to bond and seal the glass pane to the wooden frame. A good window sealant might do the trick but you will have to make sure all the old gunk is removed and the surfaces well cleaned.
BoomerD
66,401
14,797
Damn...way to try to bring the thread back on topic. :eek:
Dirigible
5,961
32
I know, right?
But, yeah. More details on the windows are needed. My windows are like 100 years old, and if a pane of glass breaks or comes loose it's a pretty easy fix. Dunno about more modern stuff.
Murloc
5,382
65
not as easy I guess.
I have metal frames with double glass and I think it's like a sandwich, metal, silicone, double glass, silicon, metal again. And there's the rest of the frame all around ofc. I don't see how the glass can become loose unless you remove all the silicone from both sides. And it's impossible to break accidentally.
I wonder how can you survive with single pane windows, I hate them with a passion, they're so cold and flimsy, you can't even lean on them without thinking it's going to break.
highland145
43,973
6,338
Even argon only gets you to ~R-3. Yeah, 300% greater than single pane but still not much. Heavy curtains/drapes....
Heat insulating properties
The effectiveness of insulated glass can be expressed as an R-value. The higher the R-value, the greater is its resistance to heat transfer. A standard IGU consisting of clear uncoated panes of glass (or lites) with air in the cavity between the lites typically has an R-value of 0.35 K·m2/W.
Using US customary units, a rule of thumb in standard IGU construction is that each change in the component of the IGU results in an increase of 1 R-value to the efficiency of the unit. Adding Argon gas increases the efficiency to about R-3. Using low emissivity glass on surface #2 will add another R-value. Properly designed triple glazed IGUs with low emissivity coatings on surfaces #2 and #4 and filled with argon gas in the cavities result in IG units with R-values as high as R-5. Certain vacuum insulated glass units (VIG) or multi-chambered IG units using coated plastic films result in R-values as high as R-12.5
I'll look up some prices on that.
spacejamz
10,981
1,701
live in North Dallas...
here is a pic of a bad window and a good window...you see the weather stripping i stuffed into the gap....LOL
Dirigible
5,961
32
Average daily highs and lows are never that high or low here, so cold isn't an issue. http://www.weather.com/weather/wxclimatology/monthly/graph/94618
And there are so many drafts in this house that window insulation isn't going to make any difference. I don't have AC and in the past have gone years on end without using the heat.
And I've never considered leaning against my windows. :confused:
