Win98 rundll32 problem?
spec74
40
Yeah i know still running win98SE sorta sucks. Anyways I freshly installed windows couple of times and still get this damn error "rundll32". Can anybody help? I even put a new HD and still getting this problem.
MrChad
13,507
rundll32 is pretty generic. Can you be more specific about the error message? When does it occur? How frequently does it occur?
spec74
40
Well the error accures always and everytime at the start up of the comp. Soon you enter window then the error pops up
jfunk
1,208
Are you getting this error on the very first boot of windows after the install?
Generally you would get this from some program running at startup. If you get this before installing anything, that would narrow it down some.
j
spec74
40
I got this error from the first boot also... so not sure what the problem is. Oh yeah not sure if this is important or not but i'm running korean version win98 SE
Jolt2
413
You many want to try reloading windows again. I have ran into weird problems with Windows9x installs when I tried loading Windows with all the hardware installed. I have ever had a problem installing Windows when I have just the basic hardware installed. After system is loaded then add one piece of hardware with the drivers for it. Make sure to reboot between hardware installs. You can then make sure everything is fine a step at a time.
