First, this is not my box. It's my gf's. I can't put up with Win95 anymore.
She's on a school network (on-campus). Her local network -does- work on her computer, but not the internet. Almost everything seems to be just fine -- no hardware conflicts, the net card and cable appear to be working fine (since the local network is fine), the net card is installed correctly in Windows, and the TCP/IP protocol is installed.
The one setting that doesn't seem to be right is WINS Configuration. I am 100% certain that it needs to be set to use DHCP for WINS. So, I set that. However, when I reboot, Windows has set it to "Disable WINS." It apparently will not keep it at DHCP.
Any help? Suggestions? Has anyone seen something similar?
Thanks in advance.
-Arschloch
Thanks in advance.
-Arschloch
