Win7 Blue screen shutdown problem
Imager
369
Hey guys! Built a new PC and it's been working pretty good, but every once and a while I'll receive a blue screen and then it will do an auto restart on me. I thought I copied the error after reboot, but it didn't take. I do remember it saying there were two location areas of files that would help explain the shutdown - if anyone knows what they are I can copy and paste the info here. My new PC specs are below. Thanks as always!
Intel i5 760
G.Skill DDR3 1333 4GB x2
4 WD Green 1.5TB drives
1 Gskill SSD 60gb
GIGABYTE GA-P55-UD3 P55 1156 PIN DDR3
Win7 64bit Enterprise
mrblotto
1,639
117
-Right click my computer-mash 'properties'
-Select 'Advanced System Settings'
-Mash the 'Settings' button for the 'Startup and Recovery' section
-Uncheck 'Automatically Restart'
Wouldn't hurt to check the Event Viewer as well instead of waiting for another B S O D
-Right Click 'My Computer' and mash 'Manage'
-Expand 'Event Viewer'
-Expand 'Windows Logs'
-Prolly look under 'Application' and/or 'System' for any Red X 'Critical' or Red (!) entries. They may give a clue on what the source of your BSOD's are.
Good luck
Imager
369
Good luck
Thanks! If I UNcheck auto restart is that going to keep the blue screen up though? I think I might rather have it reboot no?
First error log: Log Name: Application
Source: Microsoft-Windows-Security-SPP
Date: 1/28/2011 7:24:18 PM
Event ID: 8196
Task Category: None
Level: Information
Keywords: Classic
User: N/A
Computer: Media-PC
Description:
License Activation Scheduler (sppuinotify.dll) was not able to automatically activate. Error code:
0x8007232B
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Security-SPP" Guid="{E23B33B0-C8C9-472C-A5F9-F2BDFEA0F156}" EventSourceName="Software Protection Platform Service" />
<EventID Qualifiers="16384">8196</EventID>
<Version>0</Version>
<Level>4</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2011-01-29T00:24:18.000000000Z" />
<EventRecordID>4212</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>Application</Channel>
<Computer>Media-PC</Computer>
<Security />
</System>
<EventData>
<Data>0x8007232B</Data>
</EventData>
</Event>
under event viewer - application there are quite a few - Security-SPP errors that appear.
This is from System:
Log Name: System
Source: Microsoft-Windows-DistributedCOM
Event ID: 10001
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Media-PC
Description:
Unable to start a DCOM Server: {F87B28F1-DA9A-4F35-8EC0-800EFCF26B83} as /. The error:
"5"
Happened while starting this command:
C:\Windows\System32\slui.exe -Embedding
Event Xml:
<System>
<Provider Name="Microsoft-Windows-DistributedCOM" Guid="{1B562E86-B7AA-4131-BADC-B6F3A001407E}" EventSourceName="DCOM" />
<EventID Qualifiers="49152">10001</EventID>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<EventRecordID>10137</EventRecordID>
<Correlation />
<Channel>System</Channel>
<Security />
</System>
<EventData>
<Data Name="param1">C:\Windows\System32\slui.exe -Embedding</Data>
<Data Name="param2">5</Data>
<Data Name="param3">{F87B28F1-DA9A-4F35-8EC0-800EFCF26B83}</Data>
<Data Name="param4">
</Data>
<Data Name="param5">
</Data>
</EventData>
</Event>
Hope some of this helps...
somethingsketchy
1,019
Wouldn't hurt. On a similar note, is your copy of Win 7 activated? Sometimes Windows can be picky about that.
As a side note, the reason while you get an automatic reboot with a BSOD, is because it usually does that. If you some sort of hardware or memory corruption problem, a BSOD appears and then your computer will restart to "clear" itself. Sort of a fresh start.
Then if the BSOD re-appears, chances are it could either be software driver-related, or something more.
Do you have the exact verbiage when a BSOD appears? That will help us track down the issue further.
Imager
369
Yes windows is activated. I will make sure I get the "copy" down if/when it happens again. I just happened to be at the PC and doing something when it happened this time. Unless there is another place I can look to get the verbiage now?
